Manage Mediation Engine Recent Call Access
For users with ME Recent Call Access, User Management
permissions, users can enable or disable their access to ME Recent Calls, as well as
configure a length of time that represents a "recent call".
If the user does not have the appropriate user group permissions under User Management, the Admin selection under the Monitoring Manager slider does not display.To manage ME Recent Call Access permissions:
- Expand the Monitoring Manager slider and select
Admin.
The Monitoring Manager Administration page displays.
- Optionally, select a value for the Recent Calls Time
Range in Seconds. This defines the Recent Calls time range
length in seconds from the current time stamp or from the start timestamp set in
filter criteria (if any). The minimum configurable value is 1 second, the
maximum value is 2,592,000 seconds, and the default is 900 seconds.
Users can only view the last 50 recent calls per ME device.
The Current Timestamp value refers to the start timestamp of the latest recent call, however, if multiple ME devices are present, this timestamp refers to the start timestamps of the latest recent call of an ME device. - Click the ME Recent Call Access button.
The ME Recent Call Access Policy dialog displays, listing all of the ME devices available to return call data. The table contains the following columns:
Disable checkmark When selected, the Oracle® Session Delivery Management Cloud (Oracle SDM Cloud) disables that device from returning recent call data. By default, this is unchecked. Name The name of the ME to be enabled or disabled. IP Address The IP address of the ME. - Select the ME devices for which the Oracle SDM Cloud will return call data.
- Click Apply.
