7 Upgrading STAP
Learn about upgrading your Oracle Communications Solution Test Automation Platform (STAP) cloud native environment to the latest patch set or interim patch release.
Topics in this document:
Upgrading your STAP Environment
To upgrade your STAP environment:
  1. Download the new version of STAP CNTK:
    curl cntk_link cntk_zip
    unzip cntk_zip
    where:
    • cntk_link is the link to download the CNTK
    • cntk_zip is the location of the CNTK
  2. Load all the images for each microservice to be upgraded from the CNTK image folder:
    From the CNTK_home/microservice_directory:
    podman load -i image.tar
  3. Tag the images for upload:
    podman tag image_name:image_id repoDest
  4. Push the images to the repository:
    podman push repoDest
    Repeat the following steps for each microservice.
  5. Navigate to the directoryName/stap-microservice/helm_chart/ directory.
    where:
    • directoryName is the name of your STAP microservice directory
    • stap-microservice is each STAP microservice
    • helm_chart is the helm chart of the respective STAP microservice
    Update the override-values.yaml file with the new imageName.
  6. List Helm releases in the namespace to get the chart name:
    helm ls -n namespace
  7. Upgrade the Helm chart:
    helm upgrade chart_name path_to_chart_dir --values override-values.yaml -n namespace
