6 Verifying the Installation
Learn about verifying a successful deployment for Oracle Communications Solution Test Automation Platform.
Verifying a Successful Deployment
- Check if the pod is in Running state by running the following
command:
kubectl get pods -n namespace_name - Check the logs for any errors by running the following
command:
If no errors appear, the deployment has run successfully.kubectl logs pod_name -n namespace_name - Run the following command to retrieve External IP and Port Number
for the
services:
To validate Basic Auth deployment:kubectl get po -n namespace_name -o wide- TDS Service: Run the following command to check if
the service is
accessible:
The command should run without errors or connection failures.curl http://TDS_NodeIP:port/job - TES Service: Verify TES service accessibility using
the following
command:
The command should return a response without errors.curl http://TES_NodeIP:port/taas - UI Service: Open the UI in a browser using the
following
URL:
If you are able to login to the UI, the deployment is working as expected.http://UI_NodeIP:port
the service is
accessible:
- To validate OAuth deployment:
- Use the IDCS credentials to generate an OAuth access token. The token should be included in the Authorization Header as a Bearer Token for subsequent requests.
- Validate Service Accessibility:
TDS
Service
- Open Postman and create a GET request
to the
following:
https://TDS_NodeIP:port/job - In the Headers section, add the
following:
Send the request. The response should return with no errors or connection failures.Authorization: Bearer access_token
to the
following:
https://TES_NodeIP:port/taas - In the Headers section, add the
following:
Authorization: Bearer access_token - Send the request. The response should indicate successful connectivity.
- Open the UI in a browser using the following
URL:
https://UI_NodeIP:port - If required, tunnel the connection locally before
accessing the URL. You need to tunnel the connection locally
if:
- You want to access the UI through a browser but don't have VNC set up.
- Network blocks or firewalls prevent direct access to the UI.
- You can't set up a load balancer for access.
- You're working from a location without direct access to the UI.
- Log in using OAuth credentials. If authentication is successful, the deployment is functioning correctly.
to the
following:
You can verify if your environment variables are correctly set in the container by following these steps:- Run the following
command:
kubectl exec -it pod_name -n namespace -- /bin/sh - Navigate to the config directory and verify variables and values.
- If an environment variable is missing, check the deployment manifest or the override-values.yaml file for incorrect configurations.
Setting Up the STAP Design Experience
The STAP Design Experience package simplifies the automation of end-to-end scenarios by offering a user-friendly Behavior-Driven Development (BDD) environment for creating, testing, and deploying automation. For more information on the STAP Design Experience, see "Using the STAP Design Experience Package" in User Operations Guide.
Before setting up the STAP Design Experience, ensure you have installed the correct version of Java. See "Common Software Compatibility" in Compatibility Matrix,
To set up the STAP Design Experience package, follow these steps.
- Download the STAP Design Experience package, titled oc-stap-1.25.1.1.zip inside the DE.zip file.
- Unzip the files in the package. It contains the following
folders:
- lib: Contains the STAP library.
- sampleWorkSpace: Contains the sample automation workspace.
- stap: Contains the STAP command-line script.
- run.sh, compile.sh, run.cmd, and compile.cmd: Contain sample scripts to perform STAP operations.
To set up STAP Design Experience on a Linux or a Mac, see "Configuring the STAP Design Experience on Linux".
To set up STAP Design Experience on Windows, see "Configuring STAP Design Experience on Windows".
- Set the STAP environment variables using the
following
command:
export STAP_HOME=packageLoc export PATH=$STAP_HOME:$PATHwhere:- packageLoc is the location of your STAP DE package
- STAP_HOME:PATH is the path to your STAP repository
- In a new terminal window, start WireMock, which is a
mock server to run the sample scenarios.
If you are using the Bourne shell, run the following commands:
cd $STAP_HOME/sampleWorkSpace/WireMock startWireMock.shIf you are using another shell, run the following commands:cd $STAP_HOME/sampleWorkSpace/WireMock sh startWireMock.sh - Compile sample automation scenarios.
cd $STAP_HOME/ ./compile.shIf you are using another shell, run the following commands:cd $STAP_HOME/ sh compile.sh - In the same terminal window, run the sample
cd $STAP_HOME/ ./run.shIf you are using another shell, run the following commands:cd $STAP_HOME/ sh run.sh
- Set the STAP environment variables by following these steps
- Update the setenv.cmd file with the location where
the STAP DE package is extracted, by running the following
command:
set STAP_HOME=packageLoc set PATH=%STAP_HOME%;%PATH% - At the command prompt, navigate to design experience folder titled DE.zip in the CNTK folder and set the environment variables using the following command:
setenv.cmd - Update the setenv.cmd file with the location where
command:
- In a new terminal window, start WireMock, which is a mock server to
run the sample scenarios, by running the following
command:
cd %STAP_HOME%\sampleWorkSpace\WireMock startWireMock.cmd - In another terminal window, compile sample automation scenarios by
command:
cd %STAP_HOME% compile.cmdNote:
If successful, compile.cmd returns with a 100% pass. - In the same terminal window as the previous step, run the sample
automation scenarios:
cd %STAP_HOME% run.cmdIf successful, run.cmd returns with a scenario summary report in the terminal window, alongside an automation report generated in the STAP UI.
Accessing STAP Microservice URLs
After STAP microservices are deployed, you can access URLs of each microservice.
- Collect the port details by running the following
command:
kubectl get svc -n namespace - To access each microservice, run the following
command:
https://node ip:portNote:
If you do not have SSL configured, usehttp.
