Delete an existing edge based on the fromNode and the toNode
delete
/topology/v2/edge/fromnode/{fromnode}/tonode/{tonode}
Request
Path Parameters
fromnode(required): string
The fromNode entityId of the edge
tonode(required): string
The toNode entityId of the edge
Query Parameters
label: string
The label of the edge
There's no request body for this operation.
Back to TopResponse
Supported Media Types
- application/json
200 Response
The edge was deleted successfully
Root Schema : schema
Type:
string
400 Response
The request is not valid
401 Response
The request is unauthorized
403 Response
The request is forbidden
404 Response
The requested resource not found
500 Response
An Internal Server Error has occurred
