Delete an existing edge based on typeId and referenceId
delete
/topology/v2/edge/typeid/{typeid}/referenceid/{referenceid}
Request
Path Parameters
referenceid(required): string
The referenceId of the edge
typeid(required): string
The typeId of the edge
There's no request body for this operation.
Back to TopResponse
Supported Media Types
- application/json
200 Response
The edge was deleted successfully
Root Schema : schema
Type:
string
400 Response
The request isn't valid
401 Response
The request is unauthorized
403 Response
The request is forbidden
404 Response
The requested resource not found
500 Response
An Internal Server Error has occurred
