Assigning a Resource to an Activity Assignment
Perform these steps to assign a resource to an assignment that has a role designated, but currently no resource. You can also perform these steps to designate a different resource for an assignment.
- On the
Navigation Menu, expand
Resources and click Assignments. - On the Assignments page:
Tip:
The Assignment Preferences dialog box appears if either of the following Resource Assignments settings in My Preferences are set to Ask me to select each time I assign:
- When assigning a resource to an existing activity assignment.
- When a resource and role share an activity assignment.
If you select the Do not show option on the Assignment Preferences dialog box, the Resource Assignments settings in My Preferences are changed to the options that are set in the dialog box. The Assignment Preferences dialog box will appear again only if you reset one of the options above back to Ask me to select each time I assign.
- You cannot reassign a resource if the assignment has Actual Units, a project is opened exclusively, or if the project is checked out.
- When you select a resource, you can see the details for the resource, including primary role, contact information and location.
