At Completion Material Cost
At Completion Material Cost field
The material cost at completion. It is the sum of the actual plus remaining costs for all material resources assigned to the activity or all activities in the project.
It is the same as the planned material costs if the activities are not started, and the actual material costs once the activities are completed.
Calculated as Actual Material Cost plus Remaining Material Cost.
