Changing a Project Calendar to a Global Calendar
You can turn an existing project calendar into a global calendar.
To make a project calendar a global calendar:
  1. On the "" Navigation Menu, expand "" Administration and click Enterprise Data.
  2. On the Enterprise Data page, expand Projects and click Project Calendars.
  3. On the Project Calendars page:
    1. Expand a project.
      If the project you need is not open, click Open Project.... Choose one or more projects and click Open.
    2. Click on the calendar you want to change to global.
  4. Click "" Context and select Promote to Global Calendar.
  5. Click Save.
