Modifying Calendar Days on Project Calendars
Modify calendar days to account for work or nonwork days or hours that are different than the standard hours defined on the Standard Work Week tab.
- On the
Navigation Menu, expand
Administration and click Enterprise Data. - On the Enterprise Data page, expand Projects and click Project Calendars.
- On the Project Calendars page:
Tip:
The
Global Nonwork on calendar days indicates exception days in the base calendar. You can modify these exceptions days and the globe will disappear. If you set the calendar day back to standard, the Global exception day will reset and the globe will reappear.
