Configuring the Standard Work Week for Project Calendars
Configure the standard work week for the calendar to set the work and nonwork days and hours for a standard work week.
To configure the standard work week:
- On the
Navigation Menu, expand
Administration and click Enterprise Data. - On the Enterprise Data page, expand Projects and click Project Calendars.
- On the Project Calendars page:
- On the Standard Work Week tab, right-click on a working or nonworking timeslot and use the menu options to adjust the workday. You can also resize the working time to increase or decrease the work hours.
- Click Save.
