Setting Work Hours Per Period for a Project Calendar
Configure the work hours per time period settings to specify the default number of hours in a work period for a calendar.
To set the number of work hours for each time period:
  1. On the "" Navigation Menu, expand "" Administration and click Enterprise Data.
  2. On the Enterprise Data page, expand Projects and click Project Calendars.
  3. On the Project Calendars page:
    1. Expand a project.
      If the project you need is not open, click Open Project.... Choose one or more projects and click Open.
    2. Click the calendar you want to modify.
    3. Click the Summary tab.
    4. In the Time Periods section, type an hour value in each field.
  4. Click Save.
