Configuring Activity Network
Configure an Activity Network to determine how the network displays.
To configure an Activity Network:
  1. On the "" Navigation Menu, expand "" Projects and click Activities.
  2. On the Activities page:
    1. Click "" Customize View.
    2. In the Manage View dialog box, click the Activity Network tab.
    3. On the Activity Network tab:
      • Select the One field per line option to show each field on a separate line in the box. Clear this option to show two fields on each line in the box.
      • Select the fields to show in activity network boxes.
    4. Click Apply.
Tip:
This page does not affect the boxes in the Trace Network detail panel.
