Variance BL1 - Finish Date
Variance BL1 - Finish Date field
The duration between the current project finish date and the primary baseline finish date. Baseline variance columns only use data from visible activities. If you need to see variance for the whole project, remove any filters applied to the view.
Calculated as Finish minus BL1 Finish.
