Variance BL1 - Nonlabor Units
Variance BL1 - Nonlabor Units field
The difference between the primary baseline nonlabor units and the at completion nonlabor units. Baseline variance columns only use data from visible activities. If you need to see variance for the whole project, remove any filters applied to the view.
Calculated as BL1 Nonlabor Units minus At Completion Nonlabor Units.
