Variance BL Project - Expense Cost
Variance BL Project - Expense Cost field
The difference between the baseline project expense cost and the at completion expense cost. Baseline variance columns only use data from visible activities. If you need to see variance for the whole project, remove any filters applied to the view.
Calculated as BL Project Expense Cost minus At Completion Expense Cost.
