Variance BL Project - Labor Cost
Variance BL Project - Labor Cost field
The difference between the baseline planned labor cost and at completion labor cost. Baseline variance columns only use data from visible activities. If you need to see variance for the whole project, remove any filters applied to the view.
Calculated as Planned Labor Cost minus At Completion Labor Cost.
