Variance BL Project - Nonlabor Cost
Variance BL Project - Nonlabor Cost field
The difference between the baseline planned nonlabor cost and at completion nonlabor cost. Baseline variance columns only use data from visible activities. If you need to see variance for the whole project, remove any filters applied to the view.
Calculated as Planned Nonlabor Cost minus At Completion Nonlabor Cost.
