Variance BL Project - Nonlabor Units
Variance BL Project - Nonlabor Units field
The difference between the baseline nonlabor units and the at completion nonlabor units. Baseline variance columns only use data from visible activities. If you need to see variance for the whole project, remove any filters applied to the view.
Calculated as BL Project Nonlabor Units minus At Completion Nonlabor Units.
