Delete Visualizations in Projects/Shells
Project/Shell Administrators can delete visualizations from the Visualizations log of projects/shells they have access to.
You must have the Setup permission enabled for visualizations in the specific project/shell to perform this task.
To delete visualizations from the Visualizations log of a project/shell:
- Sign in to Unifier with project/shell administration credentials.
- Go to the specific project/shell tab, and switch to Admin mode. For example, select a tab called Vision Corporation.
- In the left Navigator, select Setup, and then select Visualizations.
- In the Visualizations log (right pane), select the checkbox adjacent to the Name of a visualization you want to delete, and then select Delete.
- In the Delete Item(s) confirmation dialog box, select Delete.
