Edit Content Items in the Visualization Layout
Apart from editing content items you add in the Library, you can edit content items on the visualization layout page.
To edit content items from visualizations in a project/shell (Admin mode):
- Sign in to Unifier with project/shell administration credentials.
- Go to the specific project/shell tab, and switch to Admin mode. For example, select a tab called Vision Corporation.
- In the left Navigator, select Setup, and then select Visualizations.
- In the Visualizations log (right pane), select a visualization, and select Edit.
- On the Edit page, select a content item in the visualization layout, and select Edit (
). - Make changes to the content item, and then select Update.
- On the Edit page, perform any of the following actions:
- To confirm all the changes made to the visualization, select Save.
- To discontinue the process, select Cancel any time.
