Migrate a Single Project from Oracle Primavera Cloud to Primavera P6 EPPM
For this workflow, you will activate and run the Oracle Primavera Cloud to P6 Migrate Project Sync integration.
- Go to the Integrations section of the project workspace.
- Activate the integration.
- Run the integration.
