Billable Charge Read Details Upload Staging Layout
You must create a billable charge read details upload record for each read detail to be uploaded. The name of this table is CI_BCHG_UP_READ. The following table describes each column on this table. Refer to "pass through" charges for more information about how this type of information is used.
 Column Name  |
 Length  |
 Req'd  |
 Data Type  |
 Comments  |
 BCHG_UP_ID  |
 30  |
 Y  |
 Char  |
 This is the foreign key to the billable charge upload staging record.  |
 SP_ID  |
 10  |
 Y  |
 Char  |
 Note, if USAGE_FLG is calculation, you can set this field to 0 if you do not know the SP ID. The only thing that's important is that the combination of BCHG_UP_ID, SP_ID and SEQNO are unique.  |
 SEQNO  |
 5  |
 Y  |
 Number  |
 This should be a value greater than zero. See SP_ID comment for more information. This is typically the sequence number of the register on the meter.  |
 END_READ_DTTM  |
 26  |
 Y  |
 DateTime  |
 This is the date and time of the end read  |
 END_REG_READ_ID  |
 12  |
 N  |
 Char  |
 This field must reference an existing register read ID if USAGE_FLG is anything other than a calculation.  |
 END_REG_READING  |
 9.6  |
 Y  |
 Number  |
 This is the reading of the end read.  |
 FINAL_REG_QTY  |
 12.6  |
 Y  |
 Number  |
 This is the final amount of the reading (this is the amount of billable consumption the read detail contributed to the entire billed consumption).  |
 FINAL_SQI  |
 8  |
 N  |
 Char  |
 The service quantity identifier of the FINAL_REG_QTY. If specified, it must reference a valid value on CI_SQI. Note, at least one of the following fields should be specified: FINAL_SQI, FINAL_UOM_CD.  |
 FINAL_TOU_CD  |
 8  |
 N  |
 Char  |
 The time-of-use code of the FINAL_REG_QTY. If specified, it must reference a valid value on CI_TOU.  |
 FINAL_UOM_CD  |
 4  |
 N  |
 Char  |
 The unit of measure of the FINAL_REG_QTY. If specified, it must reference a valid value on CI_UOM. Note, at least one of the following fields should be specified: FINAL_SQI, FINAL_UOM_CD.  |
 HOW_TO_USE_FLG  |
 2  |
 Y  |
 Char  |
 See the field description for valid values (CI_BCHG_UP_READ).  |
 MSR_PEAK_QTY_SW  |
 1  |
 Y  |
 Char  |
 Y or N  |
 MSR_QTY  |
 12.6  |
 Y  |
 Number  |
 This is the difference between END_REG_READING and START_REG_READING for subtractive registers.  |
 REG_CONST  |
 6.6  |
 Y  |
 Number  |
 This is the register's constant (the value used to adjust the measured quantity due to something associated with the physical meter). Set this to a value of 1 if it is not known.  |
 SQI_CD  |
 30  |
 N  |
 Varchar  |
 The service quantity identifier of END_REG_READING and START_REG_READING. If specified, it must reference a valid value on CI_SQI. Note, at least one of the following fields should be specified: SQI_CD, TOU_CD, UOM_CD.  |
 START_READ_DTTM  |
 26  |
 Y  |
 DateTime  |
 This is the date and time of the start reading.  |
 START_REG_READ_ID  |
 12  |
 Y  |
 Char  |
 START_REG_READING  |
 9.6  |
 Y  |
 Number  |
 This is the reading of the start read.  |
 TOU_CD  |
 30  |
 N  |
 Char  |
 The time-of-use code of END_REG_READING and START_REG_READING. If specified, it must reference a valid value on CI_TOU.  |
 UOM_CD  |
 30  |
 Y  |
 Char  |
 The unit of measure of END_REG_READING and START_REG_READING.  |
 USAGE_FLG  |
 2  |
 Y  |
 Char  |
 USE_PCT  |
 3  |
 Y  |
 Number  |
 This is the percentage of the consumption that was billed (this will typically be 100).  |
