Maintaining Aggregation Measuring Components
You use the Totals and Trends View portal to maintain aggregation measuring components.
Refer to About Aggregation Measuring Components for additional information.
You can access this portal by selecting an aggregation measuring component from the Measuring Component Set Participants zone in the Measuring Component Set portal. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
This portal includes the following zones:
- Measuring Component: This zone displays the basic attributes of the aggregation measuring component
 - Measuring Component Attributes: This zone displays attributes that describe the dimensions and criteria for the aggregation measuring component
Related Measuring Component Sets: This zone displays the measuring component sets related to the aggregation measuring component
Final Values Overlay: This zone graphs final measurements for a measuring component, and provides the ability to overlay the graphed data with final measurements from other measuring components. The zone also permits overlaying data from the same measuring component for different time periods, as well as data from measuring components that measuring different quantities, such as temperature.
Interval - Audit View: This zone allows users to view an interval measurement curve for a given period overlaid with the count of audit records for each individual measurement. It also allows users to magnify a portion of the curve and see how the measurements looked at different points in time.
 - Measurements - Interval: This zone displays measurement details for the aggregation measuring component
Usage Subscriptions Directly Linked to MC: This zone displays usage subscriptions that are directly linked to the aggregation measuring component
Time of Use Overlay: This zone displays an overlay of the TOU periods on measurement data along with totalized TOU consumption based on a user-defined time period and TOU map
