Maintaining Contacts
This portal is used to display a Contact.
Refer to About Contacts for additional functional information.
You can access the portal from service points, usage subscriptions, and out of service locations (when Operational Device Management is installed). When you select the contact on a service point, usage subscription, or out of service location, you are brought to the maintenance portal to view the selected record.
- Contact: defines the basic attributes of the contact
Service Points: This zone lists service points associated with the contact..
Contacts are created from Customer Care and Billing Persons via Customer To Meter Master Data Synchronization. Contacts should only be updated
via the Customer Care and Billing Person portal.
