Maintaining Dynamic Options
This portal is used to display and maintain a Dynamic Option.
You can access the portal from Menu > Usage > Dynamic Option. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
  • Dynamic Option: defines the basic information about a Dynamic Option.
  • Dynamic Option Event List: provides a list of the Dynamic Option Events that have been created for this Dynamic Option.
Dynamic Options can be created from Customer Care and Billing Contract Options via Customer To Meter Master Data Synchronization. Dynamic Options created from Contract Options should not be modified using this portal.
