Maintaining Usage Subscriptions
This portal is used to display and maintain a usage subscription.
You can access the portal from Menu > Usage > Usage Subscription. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
  • Usage Subscription: Defines basic information about the usage subscription, including factor overrides, usage groups, and service points.
  • Usage Subscription Market Participants: Lists market participants associated with the usage subscription (via Usage Subscription Market Participants)
  • Sub Usage Subscriptions: Lists the first fifty "sub" usage subscriptions for the master usage subscription displayed in the Usage Subscription zone. This zone is only displayed for "master" usage subscriptions.
Usage Subscriptions can be created from Customer Care and Billing Service Agreements via Customer To Meter Master Data Synchronization. Usage subscriptions created from service agreements should not be modified using this portal.
