Maintaining Settlement Transactions
You use the portal Settlement Transaction portal to view and maintain a settlement transactions.
Refer to About Settlement Transactions for additional functional information.
You can access the portal from the Main > Settlement > Settlement Transaction. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
- Settlement Transaction: This zone displays basic information about the settlement transaction, including processing information and settlement calculation groups.
 - Outbound Communication: This zone displays a list of outbound communications sent for the settlement transaction.
 - Calculated Data Overview: This zone displays an overview of calculated data related to the settlement transaction.
 - Calculated Data Details: This zone provides ability to query the detailed service quantity interval data for the settlement transaction.
A number of important actions are available for a settlement transaction depending on its status:
 Action  |
 Allowed Statuses  |
 Details  |
 Approve  |
 Approval In Progress Issue Detected (only when the exceptions are marked to require approval)  |
 Allows a user to bypass any exception or failure message for the settlement transaction and attempt to send it to the requesting system.  |
 Calculate  |
 Approval In Progress Pending  |
 Allows a user to trigger settlement calculations.  |
 Discard  |
 Approval In Progress Export Error Issue Detected  |
 Allows a user to discard the settlement transaction.  |
 Export  |
 Export Error  |
 Allows a user to transition the settlement transaction to the Export status and send the settlement transaction to the recipients.  |
 Export Manually  |
 Export Error  |
 Allows a user to manually export the settlement transaction send it to the recipients.  |
 Override Exception  |
 Issue Detected  |
 Allows a user to override an exception and transition the settlement transaction to the Override Exception state.  |
 Re-Calculate  |
 Issue Detected  |
 Reruns the entire process of calculation along with any validations (all settlement calculation rules) for the settlement transaction.  |
 Supercede  |
 Completed  |
 Allows a user to indicate that the settlement transaction was corrected after being sent. Sets the status of the settlement transaction to Superceded.  |
Batch Processing
The Create Scheduled Settlement Transaction (D1-CSST) batch process can be used to generate settlement transactions based on a scheduled timetable. Refer to Creating Settlement Transactions Using Batch Processing for more information about this batch process.
