About Usage Subscription Market Participants
Usage subscription market participants connects a Market, Market Participant and Usage Subscription together over a specified date range. Usage subscription market participants can be created either via the Usage Subscription Market Participant portal, or by adding a market participant to a usage subscription via the Usage Subscription portal.
Usage subscription market participants are defined by the following:
- Usage Subscription: The usage subscription for which this usage subscription market participant was created.
 - Market Relationship Type: The market relationship (Distributor, Supplier, etc.) of the market participant and its role within a market.
 - Start Date/Time: The start date/time for when the record is applicable.
 - End Date/Time: The end date/time for when the record is applicable.
 - Market Participant: The market participant associated with the Usage Subscription, including an optional ID used by the market participant to uniquely identify the account (usage subscription).
