Sidebar Area
The sidebar is a special area that is always available for display on the desktop. It displays the zones defined in the Sidebar Portal.
Open / close the sidebar. You can open or close the sidebar using the Sidebar Toggle.
Minimize the sidebar when launching the system. If desired, a URL parameter may be used to minimize the sidebar when launching the system, using the parameter minSidebar=true. Refer to Creating Application Links in External Applications for more information and examples.
Adjusting the sidebar width. You can adjust the width of the sidebar by moving the slider that separates the sidebar from the object display area. This also updates your user preferences with the new width.
The sidebar area is displayed after the Object Display area by default. (On the right for a left-to-right language and on the left for a right-to-left language). You have control over its location, width and more as part of your user preferences.
