Favorite Scripts Zone
The Favorite Scripts zone lists the business process assistant (BPA) scripts that you have defined on your user preferences. You can click on a script to execute it. You can click the Search button in the zone to search for other scripts.
If you do not see the Favorite Scripts zone in the sidebar, navigate to User Menu and click
the Preferences menu item to display the User -
Portal Preferences page. Under the Sidebar Portal row, select the Display option
for the Favorite Scripts zone.
This information is also visible in the Favorites, Bookmarks section of the menu.
