What’s New in this Release
This section describes the features and improvements in Oracle Utilities Analytics Warehouse. The following topics introduce the new and enhanced features of Oracle Utilities Analytics Warehouse in this release, and other significant changes in the documentation.
Support for Oracle Data Integrator 14c, Oracle Analytics Server 2025 (8.2), and Oracle GoldenGate 23ai
Oracle Utilities Analytics Warehouse V25.10.0.0.x has been certified with Oracle Data Integrator 14c and Oracle Analytics Server version 2025 (8.2), and Oracle GoldenGate 23ai. Oracle Data Integrator 14c is supported on Oracle Fusion Middleware 14c and Oracle Analytics Server 2025 is supported on Oracle Fusion Middleware 12c.
For the list of supported technologies, refer to the
Supported Platforms Notice section.
ETL Framework Enhancements
The following enhancements have been included as a part of this release:
Support for E-Mail Alerts for ETL Jobs
Oracle Utilities Analytics Warehouse V25.10.0.0.x supports configuration of email alerts for ETL jobs. These alerts can be configured for job failures and for long running jobs (jobs that run beyond a configured threshold).
Support for Configuration of Data Retention Period for Job Execution Metadata Table
Starting V25.10.0.0.x, Oracle Utilities Analytics Warehouse supports configuring the number of days for which job execution logs can be retained in the B1_JOB_EXEC metadata table.
NMS Star Schema Enhancements
The following enhancements have been included in the out-of-the-box Oracle Utilities Network Management System star schemas:
Support for Exclusion of Lookup on Control Zone Secondary Dimension during the NMS Star Schema Loads
Oracle Utilities Analytics Warehouse V25.10.0.0.0 supports excluding the lookup on Control Zone Secondary Dimension table during Oracle Utilities Network Management System star schema loads.
In the previous releases, Oracle Utilities Analytics Warehouse supported looking up this dimension during the Oracle Utilities Analytics Warehouse star schema load process to populate the Control Zone Secondary Dimension key column in multiple fact tables. This column was not used by customers and hence caused performance problems due to the additional lookup on the dimension and subsequent error reprocessing due to the key values getting evaluated to -99.
Starting V25.10.0.0.0, Oracle Utilities Analytics Warehouse provides an option to exclude the lookup on this dimension, thereby providing performance benefits.
Simplified Design for Control Zone Dimension Load Process
Oracle Utilities Analytics Warehouse V25.10.0.0.0 provides a simplified version of the Control Zone and Control Zone Secondary Dimension designs. It leverages the HIERARCHY_TYPE column for identification of the primary and secondary hierarchies.
Support for NMS V2.6.0.2.x, C2M V25.4.0.0.x, and WAM V25.4.0.0.x
Oracle Utilities Analytics Warehouse is now certified with Oracle Utilities Network Management System V2.6.0.2.x, Oracle Utilities Customer to Meter V25.4.0.0.x, and Oracle Utilities Work and Asset Management V25.4.0.0.x.
For more details about the supported source application versions, refer to the
Supported Source Application Versions section.
Updated Supported Platforms
Updated Supported Source Application Versions
Updated Supported Upgrade Paths
