Understanding Consumer Product Component Eligibility Criteria
Operand to be compared
Comparison operator
Comparison value
Comparison results
The comparison operator can be one of the following: <, <=, <>, =, >, >=, Between, In or Is Blank.
The comparison value is recorded in the consumer product component eligibility criteria rule.
The comparison results define what action should be taken when the criteria rules is applied. If the comparison is true or false, the result can be that the consumer product component should be applied, the consumer product component should not be applied or the next eligibility rule should be checked. If there is insufficient data, that is the operand to be compared was not found, the result can be that the consumer product component should be applied, the consumer product component should not be applied, the next eligibility rule should be checked or an error should be generated.
