Setting Up Case Management Options
The topics in this section describe how to set up the system to enable case management.
Warning:
The following topics assume you thoroughly understand the concepts described under
The Big Picture Of Cases
Installation Options
Setting Up Application Services
Setting Up Scripts
Setting Up To Do Types
Setting Up Characteristic Types
Setting Up Case Types
Parent topic
Defining Case Management Options
This site works best with JavaScript enabled
