Setting Up Notification Upload Types
Every notification upload staging record has a notification upload type. This code is one of several fields that control the type of workflow process used to process the incoming notification. Open > > to define your notification upload types.
Fastpath:
Description of Page
Enter a recognizable Notification Upload Type and Description.
Enter a value for the
Upload Condition Flag when a system condition should trigger the creation of a notification record. Refer to
System Conditions May Trigger Notification and Workflow for more information.
The values for this field are customizable using the Lookup table. This field name is NT_UP_TY_COND_FLG.
If NUS records of this type will be associated with an
Extension record, indicate the extension here along with its
Navigation Option to allow a user to navigate to the correct extension record when viewing the notification upload staging record. Refer to
Navigating to Related NUS Extension for more information.
Where Used
A
Notification Upload Staging record must reference a notification upload type.
A
Workflow Process Profile references one or more notification upload types.
Parent topic
