A Note About Programs in the Table Names Matrices
For each object described in the master data and transaction data sections, there is a "table names" section that includes a matrix listing the name of each table that is part of the maintenance object. Included in the matrix is information about the programs provided to perform object validation, referential integrity validation, key assignment and insertion. The following are some points about these programs:
• One object validation program exists for the entire set of tables for the maintenance object. The
Object Validation Batch Control column indicates the batch control used to submit the object validation. Refer to
Submitting Object Validation Programs for more information. Drilling down on the hypertext allows you to see more information about the batch control, including the program associated with it.
• A referential integrity validation program exists for every table whose key includes a parent key of another object. As described in
Submitting Referential Integrity Validation Programs, these programs are submitted using a driver supplied by the system where the batch code for the appropriate table is provided. (The driver then executes the program whose name matches the batch code). The
Referential Integrity Validation Batch Control column indicates the table's batch control / program name.
• One key assignment program exists for the parent table for the maintenance object. As described in
Submitting Key Assignment Programs, these programs are submitted using a driver supplied by the system where the batch code for the appropriate table is provided. (The driver then executes the program whose name matches the batch code). The
Key Assignment Batch Control column indicates the table's batch control / program name.
• An insertion program exists for every table for the maintenance object. As described in
Submitting Insertion Programs, these programs are submitted using a driver supplied by the system where the batch code for the appropriate table is provided. (The driver then executes the program whose name matches the batch code). The
Insertion Batch Control column indicates the table's batch control / program name.
Parent topic
