A User May Manually Change An Asset's Stock Location
Stock Location History Is Created Behind The Scenes most of the time. However, the following points describe situations that will cause an operator to manually change an asset's stock location.
• If an asset is not installed at a service point, an operator may change its current stock location using either
Meter - Location History or
Item - Location History. This would typically be done when an asset is transferred to a different stock location.
Parent topic
