Maintenance Object Viewer
The maintenance object viewer is an interactive tool that allows you to view a schematic diagram of a maintenance object. A maintenance object is a group of tables that are maintained as a unit.
To open the Maintenance Object Viewer, click the Maint. Object button in the application viewer or click a maintenance object icon in the Data Dictionary.
Note:Data Is Generated. A background process generated the maintenance object information. Refer to Application Viewer Generation for further details.
