Using the Maintenance Object Detail Panel
The Maintenance Object detail panel displays a schematic of the selected maintenance object.
In the detail panel, you can navigate using the following options:
• Click a table name to transfer to the Data Dictionary
table detail view for a table. (Click the
Maint. Object button in the toolbar to return to the maintenance object.)
• Click the service XML icon (
![Service XML icon Service XML icon](../CCB_29000/images/91AppViewer060.jpg)
) to view the XML file of the Service Program used to maintain the displayed object. (Click the
Maintenance Object button in the toolbar to return to the maintenance object.)
Parent topic
