How To Copy Appointment Periods
You can click Copy Appointment Periods to quickly create multiple appointment periods for a dispatch group by copying appointment periods from the same or a different dispatch group. The Copy Appointment Periods window opens when this button is clicked.
Mass overwrites and deletes. See the following description for how this pop-up can be used to overwrite and/or delete existing appointment periods.
In the Copy Appointment Periods window, you can:
Use Copy From Dispatch Group to define the dispatch group from which you want to copy appointment periods.
Use Copy To Dispatch Group to define the dispatch group for which you are creating appointment periods.
Use Copy To Start Date and End Date to define the period for which you are creating appointment periods. The system will display each date's day of the week and the Total Days in the period.
Use Copy Method to define how appointment periods will be copied from the Copy From Dispatch Group to the Copy To Dispatch Group. The following options are possible:
- Use Copy from the matching day in the template week if you want
to copy the appointment periods from a matching day of the week from
a template week. When this option is selected, you must identify
the Start Date of Template Week. Adjacent to this date, the
system will display:
- The day name of the start day
- The number of appointment periods in the start day
- The last day in the 7 day period (i.e., a day 7 days in the future)
- The day name of the last day
- The number of appointment periods in the last day
- For example, if you enter a Copy To period of 1-Jan-2004 to 31-Jan-2004, the system will create appointments for every Monday in this period by copying the appointment periods from the Monday in the Template Week (it will do the same for Tuesdays, Wednesdays, etc. in the Copy To period).
- Use Copy the same day repeatedly if you want to copy the appointment
periods from a Template Day. Adjacent to this day, the system
displays:
- For example, if you enter a Copy To period of 1-Jan-2004 to 31-Jan-2004, the system will create appointments for every day in this period by copying the appointment periods from the Template Day.
Before you press OK, consider if holidays during the Copy To period should be treated differently than the template days. If so:
- Use Calendar in which Holidays are Defined to define the work calendar that the system should use to identify holidays. The system will display the number of holidays it finds in the Copy To period adjacent.
- Use For Holidays, Copy the Periods from this Date to define the template day whose appointment periods should be used for holidays.
After you have carefully verified this information, press OK. Please see the following notes if you detect a mistake after you press OK.
You can also use this transaction to overwrite appointment periods. This transaction is also capable of overwriting existing appointment periods for a dispatch group. If the Copy To Dispatch Group has appointment periods in the Copy To period, the system will ask if you want to delete them and then create fresh appointment periods. If there are any appointment periods in the Copy To periods with appointments, you may not overwrite the appointment periods.
Mass Delete. If the Copy To period has existing appointment periods (and they don't already have appointments) and the Copy From Dispatch Group doesn't have corresponding appointment periods, the Copy To periods will be deleted. Refer to How To Delete Appointment Periods for more information.
