How To Overwrite Appointment Periods
The window that appears when you click Copy Appointment Periods has the ability to delete existing appointment periods (as long as they don't have appointments) and then create new ones. It works like this - if the Copy To Dispatch Group has appointment periods in the Copy To period, the system will ask if you want to delete them and then create fresh appointment periods. Please follow the instructions described under How To Copy Appointment Periods for a description of the Copy Appointment Periods functionality.
