Defining Currency Codes
The currency page allows you to define display options related to currency codes that are used by your system. Use Admin > General > Currency to define the currency codes in which financial information is denominated.
This is a standard All-in-One portal.
Most attributes are self explanatory.
Please contact your specific product to verify whether it supports a currency with more than 2 Decimals.
The External Reference may be used to define a currency whose currency code is more than three characters. To support that type of currency, define a currency code that uniquely identifies the currency in the system and use the external reference to define the currency code recognized by external products. Note that your specific integration with an external system where financial information is included may need to be adjusted to use the external reference instead of the system's currency code. Refer to the specific documentation for your integrations to confirm.
