Defining Phone Types
Phone types define the format for entering and displaying phone numbers.
To add or review phone types, choose
This is a standard All-in-One portal.
The Phone Number Format Algorithm for each phone type controls the format for entry and display of phone numbers.
Use Phone Type Flag is used to identify phone types that may have specific functionality associated with it. For example if your product had support for sending a facsimile transmittal, identify the phone type that captures a Fax number.
