Service Point - Geographic Information
The Geo page contains geographic information that defines where the service point is located. Use and navigate to the Geo page.
Description of Page
The following fields are displayed:
Geographic Type Indicate the type of geographic data.
Geographic Value Specify the coordinate value. If the entered value must be in a specific format, a description of the required format is displayed adjacent. For example, if you see the format 99A 99A 99 9, you must enter 2 numbers, followed by a letter, followed by a space, followed by 2 numbers, followed by a letter, followed by a space, followed by 2 numbers, followed by a space, followed by a single number.
If the geographic type has a required format, you must enter the geographic value in the respective format; the system will NOT convert the input value into the relevant format.
Default note. A service point's geographic data defaults from your postal default information. Refer to Setting Up Premise & Service Point Postal Defaults for more information.
