Trouble Call Process
This section provides mapping details for the following:
Refer to the Trouble Call Entry Process description for processing details on this integration point.
Trouble Call Entry Process Mapping
Oracle Utilities Network Management System Field
Oracle Utilities Customer Care and Billing Message Element
Notes
Call Source ID
call_source_ID
• Integration will get the default value from the configuration properties file and map it to the NMS Call Source ID.
• Trouble calls can be created from different external systems like CCB, IVR or web call entry. Each external system sending trouble calls to NMS will have a unique call_source_ID. This determines where the trouble call originated and makes sure the external ID passed to NMS is unique.
• NMS prefixes this value to the external ID to make it unique.
Service Point ID
service_point_ID
spId
External ID
external_ID
outageCallId
CCB passes the Outage Call ID.
Account Number
account_number
accounted
This is the customer’s account ID
Trouble Code
trouble_code
outageCodes
• Trouble code mapping setup between CCB and NMS must be the same.
• In NMS the total length of the string is the total number of distinct groups in the SRS_TROUBLE_CODES table.
• In CCB, it is the Number of Outage Code Characteristic.
Call Time
call_time
callDateTime
CallbackFlag
callback_flag
callbackRequested
In NMS, the possible values include:
'0' - callback not requested
'1' - callback requested
Defaults to '1' if no value are supplied.
If Y or N are passed to NMS, it will be translated to:
'Y' is translated to '1'.
'N' is translated to '0'
Use DVM OUCCB_OUNMS_CallBackIndicator to translate CCB value to NMS value.
Callback Before Time
callback_before_time
callbackDateTime
Alternate Phone Number
alt_phone
callbackNumber
When the integration populates this field, it should strip off all delimiters and only pass the numeric values.
Customer Phone
phone
contactNumber
• If trouble call is related to an SP, CCB pass customer phone.
• If fuzzy call, CCB pass the caller's phone.
• When the integration populates this field, it should strip off all delimiters and only pass the numeric values.
Customer Name
first_name
contactName
• If trouble call is related to an SP, the integration maps it to the main person on the account.
• If fuzzy call, the integration maps it to the caller's name.
Address Street
addr_street
address1 or location1
• If trouble call is related to an SP, the integration maps it to the customer's premise address1.
• If fuzzy call, the integration maps it to location1 (It must contain a street name or free format location description).
Address Street 2
addr_cross_street
location2
• If fuzzy call, check locationType value.
• If Street Intersection, populate with location2 (It must contain a cross street).
Address Building
addr_building
blockNumber
• If Street Segment, populate with blockNumber (it must contain a number).
Address City State
addr_city_state
city state or locationCity locationState
• If trouble call is related to an SP, CCB pass the premise city and state. Concatenation of City, State.
• If fuzzy call, CCB pass the location city and location state. Concatenation of Location City, Location State.
• The delimiter provided by the integration is always comma (,). If city or state is blank, no delimiter (,) is needed.
Call ID
call_ID
callIdentifier
• This is the call identifier's external reference ID (i.e. 911 Reference Number).
Call Taker
call_taker
userFirstName userLastName
• The name of the user who created the outage call also known as trouble call.
• Integration will concatenate First name <space> Last Name.
Call Comment
call_comment
Comments
Meet Type
meet_type
meetType
• In NMS, 1 if new appointment is set and '0' - default value for all other type jobs.
• Valid Values:
• 0 - for non-meet calls
• 1 - create new meet
• 2 - reschedule existing meet
• 3- cancel existing meet
• CCB gets the value from FA Char.
• use DVM OUCCB_OUNMS_MeetType to translate CCB value to NMS value.
Meet Time
meet_time
meetDateTime
CCB will populate meetDateTime only if meet type = 1.
Call Cancel Flag
cancel_flag
Y or null (base on Status)
• If Status is Canceled, the integration populate this field with Y, otherwise it is null.
• use DVM OUCCB_OUNMS_CallCancelIndicator to translate CCB value to NMS value.
Update Existing Record Flag
update_flag
outageCallAction
• The possible values in NMS are:
0 - insert new call
1 - update existing call
• Use DVM OUCC_OUNMS_NewCallIndicator to translate CCB value to NMS value.
Device ID
device_ID
transformerId
May be null if trouble call is not related to a specific SP.
In CCB from SP Geo Code for Device.
For Fuzzy Calls: If Location is a street intersection, the mapping of the location from CCB to NMS will be p_customer_address = location1 (street name) and addr_cross_street (cross street). If Location is a street segment, the mapping of the location from CCB to NMS will be p_customer_address = location1 (street name) and addr_building (block number, this must only be a numeric value).
If Location is other (free format description), the mapping of the location from CCB to NMS will be customer address = location1 (location description).
All DateTime coming from CCB will be converted to the ISO8601 format which is YYYY-MM-DDHH:MM:SS.
Trouble Call Request Message Mapping
Oracle Utilities Customer Care and Billing Trouble Call Request Message
Oracle Utilities Network Management System Trouble Call Stored Procedure Input
Element Name
Parent Element
Type
Element Name
DVM Mapping
requestMessage
Outermost
Tag
outageCallId
requestMessage
Field
external_ID
spId
requestMessage
Field
service_point_ID
premiseId
requestMessage
Field
accounted
requestMessage
Field
account_ID
contactName
requestMessage
Field
first _name
contactNumber
requestMessage
Field
Phone
callIdentifier
requestMessage
Field
call_ID
callDateTime
requestMessage
Field
call_time
OutageCallAction
requestMessage
Field
update_flag
Status
requestMessage
Field
cancel_flag
faComments
requestMessage
Field
call_comment
userId
requestMessage
Field
userFirstName
requestMessage
Field
call_taker
userLastName
requestMessage
Field
call_taker
country
requestMessage
Field
addressLine1
requestMessage
Field
addr_street
addressLine2
requestMessage
Field
addressLine3
requestMessage
Field
addressLine4
requestMessage
Field
houseType
requestMessage
Field
number1
requestMessage
Field
number2
requestMessage
Field
inCityLimit
requestMessage
Field
city
requestMessage
Field
city_state
geographic
requestMessage
Field
county
requestMessage
Field
state
requestMessage
Field
city_state
postal
requestMessage
Field
locationType
requestMessage
Field
blockNumber
requestMessage
Field
addr_building
location1
requestMessage
Field
addr_street
location2
requestMessage
Field
addr_cross_street
locationCity
requestMessage
Field
addr_city_state
locationState
requestMessage
Field
addr_city_state
meetDateTime
requestMessage
Field
meet_time
meetType
requestMessage
Field
meet_type
outageCodes
requestMessage
Field
trouble_code
transformerId
requestMessage
Field
device_ID
callbackRequested
requestMessage
Field
callback_flag
callbackDateTime
requestMessage
Field
callbackNumber
requestMessage
Field
alt_phone
customElements
requestMessage
