Configuration Properties File
This section lists the configurations stored in the OUCCBOUNMSConfigurationProperties.xml file located under the apps/CCB-NMS/AIAMetaData/config directory.
For information on modifying configuration properties refer to the “Configuration Properties” section in Chapter 3: Configuration Guidelines.
The following types of configuration properties are managed in the configuration files:
• Module Configurations: Module configurations are the properties that are shared by multiple processes within this integration.
• Service Configurations: Service configurations are the properties that are used by a specific ABCS.
