Oracle ERP Product Hub Cloud Integration to Oracle Utilities Work and Asset Cloud Service for Stock Item Configuration Guide
Overview
Overview of the Integration
About Oracle ERP Product Hub Cloud
About Oracle Utilities Work and Asset Cloud Service
About Oracle Integration Cloud
Software Requirements
Prerequisites
Supported Business Processes
Solution Architecture
Solution Overview
Business Flows
Initial Load Item Synchronization Process (Oracle ERP Product Hub Cloud Initiated)
Incremental Sync for Item Create Process (Oracle ERP Product Hub Cloud Initiated)
Incremental Sync for Item Update Process (Oracle ERP Product Hub Cloud Initiated)
Configuring Oracle Utilities Work and Asset Cloud Service
Configuring Admin Data
External System
Inbound Web Service (IWS)
Master Configuration Setup
Business Object
Expense Code and Vendor Location Setup
Scheduling the Batch Process
Managing Catalog Services
Configuring Oracle ERP Product Hub Cloud
Oracle ERP Product Hub Cloud Overview
Oracle ERP Product Hub Cloud Portal
Oracle ERP Product Hub Cloud Features
Manage Trading Community Source System
Defining Spoke System
Manage Item Rule Set
Defining File Size of the Extract
Creating Catalogs/Categories
Importing, Configuring, and Testing Integration Connections
Importing the Oracle Integration Cloud Package from Oracle Cloud Marketplace
Verifying the Package Import
Configuring Connections in Oracle Integration Cloud
Configuring Oracle Utilities ERP Cloud for WACS-ERPPIM Connection
Configuring Oracle Utilities REST WACS for WACS-ERPPIM Connection
Configuring Oracle Utilities SOAP UCM Gen Svc for WACS-ERPPIM Connection
Setting up Certificates for Security
Configuring Lookups, Error Handling, and Email Notifications
Configuring Lookups
Editing Lookups
Configuration Properties
Error Handling
Error Handling Ways
Resubmitting the Error Instances in Oracle Integration Cloud
Email Notifications
Activating the Integration Flows
Prerequisites
Activating Integration Flows
Monitoring and Troubleshooting
Monitoring Integration Flows
Troubleshooting
Oracle ERP Product Hub Cloud Integration to Oracle Utilities Work and Asset Cloud Service for Stock Item Release 22C Configuration Guide
