Metadata Store (MDS) Artifacts
Individual Metadata Store (MDS) folders may need to be undeployed, deployed or updated for incremental builds or patches. This section describes the following:
Please note the following:
• You can only use the indicated commands to perform folder-level undeployment, deployment or update. The commands do not support file-level actions.
• Validate the MDS Folder Name parameter when prompted with default values during undeployment or deployment. Press ENTER to use the default value.
• The MDS Folder Name represents the name of the folder to be deployed or undeployed from MDS repository. The folder name should be a relative path inside <PRODUCT_HOME>/MDS-Artifacts beginning with C2M-NMS.
• The folder includes an MDS-Artifacts subfolder which contains all the files that can be deployed to MDS.
Example: To undeploy <PRODUCT_HOME>/MDS-Artifacts/C2M-NMS/AIAMetaData/dvm pass C2M-NMS/AIAMetaData/dvm as the MDS Folder Name.
