Solution Overview
The technical aspects involved in the integration between Oracle Utilities Analytics Insights, Oracle Utilities Digital Asset Cloud Service and Oracle Utilities Grid Edge Distributed Energy Resources Management System are:
•	The integration layer consists of integration processes deployed on Oracle Integration Cloud.
•	The integration processes interact with other applications using the following adapters:
•	Oracle Utilities Adapter interacts with the DACS REST APIs and NMS Grid Edge DERMS REST APIs.
•	REST Adapter interacts with Oracle Cloud Infrastructure Object Storage APIs.
•	FTP Adapter interacts with Oracle Utilities Digital Asset Cloud Service On Premise Server to list, get, and rename files in the server.
•	Two types of email notifications can be configured in this integration, namely, business, and technical error email notification. Email notifications are optional, but are enabled by default.
1.	Business email notifications:
	These notifications are used in file processing flows.
	Configure the following properties in lookup OUTL-BRT-OUAI_DACS_DRMS_ConfigProps to enable and disable notifications:
•	Property name notification.email.process.complete.flag to 'true' to receive email notification when the process is completed or partially processed. By default, this is set to 'true'.
•	Property name notification.email.process.nofile.flag to 'true' to receive email notification when no file is found in the source location. By default, this is set to 'true'.
	The recipient(s) of these email notification are configured in the dacs.to.process.notification, drms.to.process.notification and ouai.to.process.notification recipients of the OUTL-BRT-OUAI_DACS_DRMS_Email_ID lookup. These are sent to the business users of the applications.
2.	Technical error email notifications:
	This notification is sent when a technical fault is encountered. Some examples are authentication error, connection issues, or server unavailable.
•	Configure the property name notification.email.error.flag in the OUTL-BRT-OUAI_DACS_DRMS_ConfigProps lookup to 'true' to receive email notification when errors are encountered. By default, this is set to 'true'.
•	The recipient(s) of the email notification sent out for technical errors is configured in the to recipients of the OUTL-BRT-OUAI_DACS_DRMS_Email_ID lookup. These are sent to the administrators of the applications.
Note: Email notifications are optional but are enabled by default.
•	The OUTL-BRT-OUAI_DACS_DRMS_ConfigProps lookup is used to define the default values needed by the integration flows. Make sure the properties in the lookup are configured.
•	Integration related DVM lookups are used for translation of values from one application to the other. Make sure these DVM lookups are configured.
•	In the Oracle Utilities Digital Asset Cloud Service initiated processes, batch processes are used to send outbound messages to pull file(s) from a content server or to create file(s) and upload to the content server defined for an external application to pull for processing.
	Oracle Utilities Digital Asset Cloud Service uses REST inbound web services (IWS) to receive messages.
•	In the Oracle Utilities Grid Edge Distributed Energy Resources Management System initiated processes, events are triggered to send the outbound messages and files if applicable. Oracle Utilities Grid Edge Distributed Energy Resources Management System uses REST APIs to receive messages or files.
•	In the Oracle Utilities Analytics Insights all data are transferred through files. Any incoming or outgoing files are placed in an Oracle Cloud Infrastructure Object Storage.
•	For Scheduled Integration processes related to file transfer, make sure the dependent application extract processes are ran first so the files are already available in the content server for the integration process to pick up.
One-way Asynchronous
The one-way asynchronous integration process:
1.	Receives request message from the source application.
2.	Transforms message from the source to the target format. Lookups are used for data translations, if applicable.
3.	Invokes target application to send the request message.
4.	In case of any error, the global fault handler catches the error.
5.	An optional email notification is sent to the respective users as configured.
