ESRI ArcGIS Integration to Oracle Utilities Work and Asset Cloud Service Configuration Guide
Preface
Audience
Documentation and Resources
Updates to Documentation
Documentation Accessibility
Conventions
Acronyms
Introduction
Overview of the Integration
About Oracle Utilities Work and Asset Cloud Service (WACS)
About ESRI ArcGIS (ArcGIS)
About Oracle Integration Cloud (OIC)
Supported Applications
Solution Architecture
Solution Diagram
Business Flows
OU WACS OIC GISMapping Sync (Oracle Integration Cloud Scheduled Job)
ArcGIS Asset Synchronization
OU ArcGIS WACS Asset Sync (Oracle Integration Cloud Scheduled Job)
OU ArcGIS WACS Initial Assets Sync (Oracle Integration Cloud Initiated)
OU ArcGIS WACS Incremental Assets Sync (Oracle Integration Cloud Initiated)
OU WACS ArcGIS Assets Update (Oracle Integration Cloud Initiated)
Common OS Process (Oracle Integration Cloud Initiated)
Common FTP Process (Oracle Integration Cloud Initiated)
Common Notification Handler (Oracle Integration Cloud Initiated)
Configuring Oracle Utilities Work and Asset Cloud Service
Managing Catalog Services
External System
Master Configuration Setup
ESRI WAM Integration Master Configuration
Master Data Synchronization Configuration
Seeder Sync Request Master Configuration
Asset Details Extendable Lookup Mapping
Batch Jobs
Importing, Configuring, and Testing Integration Connections
Importing the Oracle Integration Cloud Project Based Accelerator Package from Oracle Cloud Marketplace
Verifying the Project Import
Configuring Connections in Oracle Integration Cloud
Configuring OU REST for ArcGIS-WACS
Configuring OU REST OIC for ArcGIS-WACS
Configuring OU REST WACS for ArcGIS-WACS
Configuring OU REST WACS Object Storage for ArcGIS-WACS
Configuring OU FTP WACS for ArcGIS-WACS
Configuring OU REST ArcGIS for ArcGIS-WACS (and for S2,S3)
Configuring Agent (if applicable)
Possible Combinations
Creating an Agent Group
Downloading Agent Installer
Installing On-Premises Agent
Configuring Lookups, Error Handling, and Email Notifications
Configuring Lookups
Editing Lookups
Configuration Properties
Error Handling
Summary of Integration Error Handling
Errors in Integration Processes
Email Notifications
Activating and Testing the Integration Flows
Prerequisites
Activating Integration Flows
Customizations
Monitoring and Troubleshooting
Oracle Utilities Work and Asset Error Logs
Monitoring Integration Flows
Troubleshooting
Things to Remember, Limitations, and Workarounds
Multiple Portal Servers
ESRI ArcGIS APIs
ESRI ArcGIS API Processing
ArcGIS Errors
Special Character Handling
ArcGIS “Maximum Number of Records Returned by Server”
ESRI ArcGIS Integration to Oracle Utilities Work and Asset Cloud Service Release 25.10 Configuration Guide
