Oracle Utilities Digital Asset Cloud Service Integration to Oracle Utilities Edge Distributed Energy Resources Management System Configuration Guide
Preface
Audience
Documentation and Resources
Documentation Accessibility
Conventions
Acronyms
Overview
Overview of the Integration
About Oracle Utilities Digital Asset Cloud Service (DACS)
About Oracle Utilities Edge Distributed Energy Resources Management System (Edge DERMS)
About Oracle Integration Cloud (OIC)
Software Requirements
Prerequisites
Supported Business Processes
Solution Architecture
Solution Overview
One-way Asynchronous
Solution Diagram
Integration Flows
Enrollment Request (Edge DERMS Initiated)
Enrollment Sync Process
Device Status Check and Acknowledgment
Program Event Status Update (Edge DERMS Initiated)
Event Device Reservation (Edge DERMS Initiated)
Event Device Outcome (Edge DERMS Initiated)
Customer Event Opt Out Update (DACS Initiated)
Program Rule Sync Process
Aggregator Sync Process
SP Network Location Transfer (Edge DERMS Initiated)
Send Device Score (DACS Initiated)
Common Integration Flows
Common Error Handler (OIC Initiated)
Configuring Oracle Utilities Digital Asset Cloud Service
Configuring Admin Data
Message Senders
External System
Inbound Web Service (IWS)
Master Configuration
Head End System
Controllable Asset Specification
Program Type
Program
Activity Type
Communication Type
Service Task Type
Sync Request Process
Scheduling Batch Jobs
Enrollment - Sync Request Monitor Process
Program Rule - Sync Request Monitor Process
Aggregator - Sync Request Monitor Process
SP Network Location Batch Processes
Device Score Batch Processes
Managing Web Service Catalog
Adding Oracle Integration Cloud Certificates
Configuring Oracle Utilities Edge Distributed Energy Resources Management System
Configuring DRMS Parameters in Oracle Utilities Edge Distributed Energy Resources Management System
DRMS Parameters
Importing, Configuring, and Testing Integration Connections
Importing the Oracle Accelerator Project from Oracle Cloud Marketplace
Verifying the Project Import
Configuring Connections in Oracle Integration Cloud
OU REST DACS for DACS-DERMS Connection
OU REST DERMS for DACS-DERMS Connection
OU REST for DACS-DERMS Connection
OU REST MP OIC for DACS-DERMS Connection
OU FTP DACS for DACS-DERMS Connection
OU REST DACS Object Storage for DACS-DERMS Connection
Configuring Agent (if applicable)
Possible Combinations
Creating an Agent Group
Downloading Agent Installer
Installing On-Premises Agent
Setting up Certificates for Security
Configuring Lookups, Error Handling, and Email Notifications
Configuring Lookups
Lookups
Editing Lookups
Lookup Tables
Configuration Properties
Error Handling
Summary of Integration Error Handling
Resubmitting the Error Instances in Oracle Integration Cloud
Email Notifications
Customizations
Monitoring and Troubleshooting
Cloud Service Logs
On-Premise Application Logs
Monitoring Integration Flows
Troubleshooting
Limitations and Workarounds
Oracle Utilities Digital Asset Cloud Service Integration to Oracle Utilities Grid Edge Distributed Energy Resources Management System Release 25.4 Configuration Guide
